warndogg
- Joined
- Mar 14, 2015
- Posts
- 93
- Reaction score
- 35
So this is a long post, but it started with the reduced engine power/ stability system disabled warning on the dash- (code was for throttle position sensor).
So I replaced the throttle body and it seemed to go away for a few months. Then it came back, so the gas pedal assembly was replaced. I disconnected the battery. Let it sit for a good hour, reconnected batt. Now its worse. When key is turned to on position there is a grinding sound coming from the new throttle body. This can't be normal. I thought it was maybe part of the re-learn? But then I get the reduced engine power immediately on start up.
Also I have checked ground at firewall, frame, and engine block. And all other wires look good. Any one else have this noise from TB after replacing?
2006 yukon denali 6.0
