feeling knocking or rattling through steer column 04 Tahoe. 2WD
Dixieman
I checked the knuckle at the end of the steering shaft, a little movement but not enough to make me think that is the problem. Seems to lessen after driving a while. Front shocks are very worn. Feels and sounds like it is on the drivers side. Anybody familiar with this.
M1Gunner
Gainesville, Fl
Well you may have solved this yourself. If your shocks are done then they no longer provide any dampening but start to enhance the vibrations which in turn could be your issue.
D
Dixieman
Well you may have solved this yourself. If your shocks are done then they no longer provide any dampening but start to enhance the vibrations which inlem turn could be your issue.
ND THEN
Just found a thread last nite about the intermediate steer shaft wearing out being a common problem.
Gonna replace shocks since i need to do anyway and then steer shaft if necessary.
corvette744
2004 Z-71
Northern illinois
ND THEN
Almost always is the steering shaft if felt in the steering wheel very common i did mine already.Dealer i bought it from was convinced it was the pitman arm they were stupid.
BrentL9900
