Eliminate Autoride Message light
05whitenali
Yea I can't imagine why the A/C would have anything to do with the same thing as the autoride and suspension. I will have to try it again and see what happens. It is just the green 30 amp fuse located in the front of the fuse box under the hood labeled RTD correct?
05whitenali
Well I tried it again this evening and it worked out perfect this time. Just pulled the fuse and when I hooked the battery back up the message was gone and the A/C was still blowing cold this time. Thanks guys.
Alex33
Glad you got it right :Handshake:
myfirstyukon
RTD fuse
Just so everyone knows this fuse is also for the speed sensitive steering.
05whitenali
What does the speed sensitive steering do? Also, I have been searching a little and can't seem to find it yet, but is there any way to get the tire pressure monitor message to stop coming up?
Alex33
In general, a speed sensitive steering system will adjust the power assist with speed, e.g. at slow speeds you'll get more assistance than at higher speeds. I did not notice a difference in steering when I removed mine.
BTRStang
Thanks for the info will do it to mine in the morning! Also any info on the tire pressure warning.... Would like to turn it off also....
johnnunez29
i just removed the fuse today and had a similar problem. my front a/c stopped working all together while my rear a/c was just fine! i removed and replaced the fuse a few times then finally my front a/c blew HOT air then went to cold air and is now blowing cold. after a mission trying out all the fuses
Cerberus66
Worked like a charm for me, even seem to help some other memory functions like the seat exit function, Prior to doing this my seat would buckle about, now it pulls right back with out a problem......
jerodmortensen
