EGR/AIR/Charcoal Canister Delete
_Dylan_
STAY FROSTY
You could try searching what they do on buick 3800s? I know they also have AIR systems.
Gzes
the drifting 2dr
Wichita tx
It doesnt look hard to remove just u might need plugs to cover where they drilled holes.for the system
noJeepshere
Bountyfull, Utahrd
just leave it place and work around it it is there for a reason.
It's there because the all-knowing and infinitely wise government regulators know that choking an engine on its own waste is the best thing to make it run better. Same with catalytic converters, "let's make this thing that restricts airflow, gets dangerously hot, and is retarded expensive, just so that ALL the gas gets burned before it exits the tailpipe". If the governement truly wanted cars to get better economy with fewer emissions, the EPA would have told manufacturers to make these emissions and this fuel economy, by this date, on your own, or get fined, BIG. My dad used to run a tune-up shop where about all he would do is take cars that came in making next to no power and 10 mpgs, swap the 2bbl chokerator for a 4bbl, delete all the emissions stuff, advance the timing, and send it out the door able to burn its tires for a block and get 25 mpgs. It's the same story with diesels right now.
Chuck 2015 Tahoe
