Cleaning Leather Seats
Larryjb
What kind of brush should I use? I know some hard ones can damage the leather?
I saw one person used a horsehair brush, it looked like a shoe polishing brush. I used a clean paintbrush. The brush idea works quite well, but the hot cleaner worked really well. It still took several attempts on my seats, but I was removing 14 years of ground in dirt.
Larry
08HoeCD
No-go on the steam clean for leather.
I haven't had the need to deep-clean leather in a long time, but I used to use Lexol with good results.
Jason_S
I am a fan of saddle soap and the soft bristle brush found in the shoe shine kits. It wont remove dye from blue jeans, but it did an amazing job of getting all of the dirt out of the creases and grains in the light gray leather in a BMW that I used to own.
08grey
A hand/nail cleaning brush usually works real good.
adventurenali92
Big Bear Lake, ca
From a detailer's perspective some of those ideas mentioned above scare me! Haha. From watching other detailers I know it's pretty easy to damage leather. The way I learned is pretty simple. I buy most of my detailing products from chemical guys based out of LA. I buy their leather cleaner and their conditioner. Spray on cleaner from bottle and scrub with a soft bristled brush. Once dirt is loose than I towel dry with my microfibers that are only for seats. My leather doesn't get very dirty so it only takes one scrub to get clean. But if leather is very dirty repeating the process twice usually will do the trick. Then I follow behind with the conditioner on another clean, dry seat microfiber. I'll snap a few pics of the products and towels.
02Lightning
I’ve used Murphy’s oil soap and a microfiber cloth with good results. Then follow with a conditioner. The leather gets that dull look back to it.
Larryjb
Before I read this thread, I was using a product called "TuffStuff" Leather cleaner and conditioner (mistake, BTW). Now the protectant has locked in dirt that wouldn't come out the first time. Even the chemical Guys cleaner won't cut through the layer. Where I didn't use Tuffstuff, Chemical Guys cleaner does an excellent job. Suggestions?
Larry
Larry
Scrubbing Bubbles Bathroom Cleaner. It's not something I'd use often but it took 15 years worth of dirt and grime off my leather and doesn't appear to have damaged it. Use it with a scrub brush, in small areas, followed by a clean cloth before it dries. Then use a leather conditioner.
adventurenali92
Big Bear Lake, ca
Larry
Chemical guys also makes a product called fabric clean that's made for upholstery shampoo. It also works well on leather and it's a little bit stronger. You might try it.
35thpewterz
