Change the color of your 00-02 Tahoe/Yukon AC control backlights with LEDs
Larryjb
I got the knobs off OK. It took gently prying with a screwdriver while lifting up on the knob itself.
I have a new question now. The only bulbs that are burned out are the tiny indicator lamps for the recirc button and defog button. These use the smaller 3.2mm (0.125") bulb instead of the 4.2mm (0.156").
Does anyone know of a source of these lamps?
Thanks.
Larry
Larryjb
I found a local supplier of the smaller bulb. The package said the bulbs were rated at 100 mA. They tested the bulb and actually got 43 mA, so they were mislabeled. The cold resistance of the old bulb was about 50 ohms, and the cold resistance of the new bulb is about 30 ohm. (Don't go by cold resistance when choosing a bulb, I only did that as a comparison). The original bulb was probably closer to 20 mA, but this one is close enough. I now have all my defog/recirc/AC buttons lit at night. :)
I think this is the bulb http://leeselectronic.com/en/product/5322.html
If you're in the Lower Mainland, these guys are great. They have just about any electrical component you need.
Larry
S
ScottyBoy
Shreveport, La
Larry
Glad you found some good stock replacement bulbs. I wish we had a good electronic parts supplier store here like that. All we had were Radio Shack stores, and most of those closed down. There are only two left and they only sell cell phones now.
I'm glad that this thread helped you to get your bulbs replaced. Even though I did the write up showing how to replace the bulbs with LEDs, I see its helped others too who just wanna replace the bulbs with the same type of factory style bulb. :Handshake:
jarydM
Lost in the Woods
Tennessee
is there a specific type of bulb to use for this in the steering wheel control button, I don't know that I have the room for a resistor too, are there LED's that would be "plug and play" with a bit of solder work?
S
ScottyBoy
Shreveport, La
I have done steering wheel buttons in both 3mm and with 5mm LEDs. The 3mm actually fit better, but for some reason they don't last as long as the 5mm do. I've had people tell me that they burned out in as fast as 3 months after I did them. I now squeeze a 5mm in there and it's VERY tight. I have to put the resistor right up tightly against it. Sometimes I even end up cutting of filing the "lip" off the bottom edge of the LED so that the resistor will fit that much tighter against it, even that 1mm or whatever it is helps as far as fitting it in there.
jarydM
Lost in the Woods
Tennessee
all of mine are out, so I'm willing to risk breaking one, or messing it up to learn how to do this. Where do you order from? I don't really know even where to start as to what parts to look for.
work computer is being sluggish in letting me read through this thread too, so if it's in here somewhere, I guess I'll find it.
also, thanks for the help @ScottyBoy
ladorn45
Has anyone tried to remove the blue film on the AC control. I want to shine white but keeps coming out blue from the film
S
ScottyBoy
Shreveport, La
Seeing as this is from 2010, is the offer still good?
I obviously missed this post almost a year ago, but yes the offer still stands. Anyone interested just send me a PM. I have done countless LED conversions and instrument cluster repairs for many members on here and several other forums. There's quite a few on here who I am sure would vouch for my good work.
S
ScottyBoy
Shreveport, La
No, I have not successfully been able to remove the blue from the AC panel, or any other switches that have it. I HAVE however learned how to remove the bluish film from the instrument cluster overlay.
mikevisalli
