Back Up Lights not working
emann_01
emann_01
i'm betting that it's the backup lamps relay in the underhood fuse box.
Yeah I think this might have something to do with with but unfortunately I dont think its a replacable relay...is this right? I will have to replace the entire underhood circuit board?
Also, could any of this be causing the issues with the license plate lights and the trailer brake wires?
emann_01
emann_01
i found this thread: http://www.gmtruckclub.com/forum/threads/reverse-lights-on-constantly.130727/
it looks like you might need to replace the whole fuse box. maybe you can find someone local that will let you swap them out to test the theory.
Yeah, I read that exact same thread and thats what led me to think I need the entire cicuit board....
I went ahead and purchased one from gmpartsdirect...should be here Friday. Hopefully this fixes the issues!
I will give an update once I swap them out.
emann_01
emann_01
So I swapped out the whole fuse box and problem solved! Reverse lights are working and trailer brake controller is hooked up and functioning.
I still have to get the license plate lamps to work but I think that is a bulb issue.
Shimmy23
WA
To clarify, you replace the fuse box?
GM 19210438
jarhead1017
