Autoride conversion to standard shocks
subieworx
I had resistors and still had the light. Pulled the fuse and the light turned off.
mrpep
What shock do you recommend for a 2003 Yukon Denali that will tow a 500 lb tongue weight camper twice a year?? I put some economic monroes but feel like they might now handle . They are the 32348
pnwdan
Cunning linguist
Arlington, WA
No matter what shock you get, you'll want to add helper bags if you tow.
Sent from my SM-N920V using Tapatalk
mrpep
What are they? Can you post a link? And so the coil springs and shocks alone not cut it ?
subieworx
I would do a normal rear spring with normal shocks. I have a set left over that I used for about s year from strut masters that worked well. It lifts the rear about an inch and is very level with a trailer attached.
mrpep
My end is actually level now since I placed the gas shocks.
subieworx
It won't be once you out weight on it though as the stock spring is very soft. It is designed to work along with the factory air spring in the shock.
mrpep
I do use aweigh T distribution hitch. Think that would help ?
mrpep
Hm, so what's ideal??
TiGrayMSM
