6inch lift w/ leveling kit?
Symba_The_Lyon
As anyone done this with with there 2 door? Pictures would be grate if you're truck has both thank you!
yates ™
Resident Apple hater
Iowa
Wouldn't a "leveling kit" just be keys? You ride may suffer depending on how the lift kit is setup.
bowtiefreak
No Quarter
Near Philly
Yates is correct, the leveling kits is keys...simply cranking them up to raise the front of the truck. My tahoe has a small 1.5" crank.
bowtiefreak
No Quarter
Near Philly
my keys are stock. Keys do not alter the ride though, the cranking them up too high or too low does. The suspension arms needs travel (not to close to the stops), if you have travel and decent shocks all is well. Mins is a little stiff due to improper valving of the shocks but I'm fixing that.
holeshot
Texas
I have a pro comp 6" kit with keys. Because of the keys I had to have 8" of lift in the back to level it out. I also have a 3" body lift. My tires are 38" Toyo's and have no rub at all. Tires are almost out of the wheels wells.
TheAutumnWind
Not much room for flex in that rig! Looks badass though.
Juicifer
Atlanta, GA
did you add taller gearing in the front/rear diff?
MrRuiz
