5.7 96 throttle body and manifold difference
ccapehartusarmyINF.(ret)
Gilbert AZ
what is the stock size of the throttle body like on my 5.3 01 suburban i heard they are 75mm
and is it worth it to go with 80 85 or maybe even 90mm TB
also does porting and polishing yer TB really do much
jerryjoe28
That Guy
cabot AR
the BB tune is what I noticed the most gains from. really makes everything work together
L
lifted2X4chevy
I think it helped a lot, there was a bottle neck on the bottom side of TB of about .125 of a inch. I removed that and if you look at pictures close you will kind of see 2 angles on upper side of blade. I tried i ported to one staight angle. I did break thur to outside, I had it weld and polished back out.
Going that big depends on how large the hole is in the actual manifold. I know LS motors you can buy intake manifold up to like 104mm i think.
Off Road Pedia
