2020 Suburban BDS suspension from ZW7 Smooth ride suspension
rediron
The shop ordered the 6" coil over w/ BDS upper control arms kit for my 2020 Chevy Suburban (comes with fox 2.5 Coilovers in the front and fox 2.0 shocks for the rear)
My Suburban doesn't have Magneride or Autoride, but I just noticed
that in my RPO codes, I have an RPO Code: ZW7 - Chassis Package,
Premium Smooth Ride
Even though this isn't Magneride or Autoride, does anyone know if that means my Suburban needs to use either the 6" Magneride or 6" Autoride kit instead of the
6" Coilover kit?
BDS says they havent heard of Smooth ride before and asked if I had a solid rear axle or not.
When I decode my VIN, it says the front axle is an "Independent" axle and the rear is a "Semi-Floating" axle
olyelr
Elk Rapids, MI
Your burb has a solid rear axle.
The If you dont have mag ride or rear air shocks everything will be fine. Otherwise you will have to play minor games with electronics. Not a big deal.
mb1500
No worries, let them install as normal.
Smooth ride for these years is basically nothing.
golavaman
