First post, so I hope I am doing it correctly. On several occasions the radio and transmission cut out as if electronically they are no longer connected. This can last as long as 30 seconds. The first indication is the radio goes off completely or acts as if it is losing the signal. At the same time the transmission is no longer working at all. The engine runs fine during this but you cannot go anywhere, no gears at all. Usually you have to glide over to the side of the road, wait for the radio and transmission to re-engage and then the car operates correctly. This can happen soon after you have just begun driving or hours after you have been driving. I have checked, cleaned, and reattached all connections to the battery and engine including grounds. This seems to be electrical?? since the radio goes off during the problem. Was wondering if their is a separate ground that connects the transmission and radio or some connection between the two?? Any help would be wonderful!
