2003 Tahoe 4.8 4x4
Hyder12
Changed rotors all the way around. Once finished started up pumped up breaks and had service break system light and the parking break light on. Fluid is full have breaks just light is annoying and don’t know why came on. Lights were not on before rotors were replaced
wjburken
Eastern Iowa
Have you put a good code reader that can read ABS codes and see what it’s showing? That’s where I’d start.
Is the ABS light on as well?
Might also check the vacuum hose going to your booster to make sure it didn’t work loose somehow.
H
Hyder12
I haven’t used scanner yet. The abs light only comes on once in blue moon but goes off min you start forward. Checked and vacuum line is good
Luggz
