Ok so I started today to replace the A/C Compressor Pump.
I have the old one out and it has a purple switch on the tail end cap held in with a snap ring.
The new supposable OEM Replacement which is a Delphi has that port with a cover and snap ring holding the cover in.
I would like to install a new switch there before I go in with the new Compressor Pump.
What is the switch called and Do I remove the cover and install the switch or should I look for a compressor pump with that switch already in.
I will post some pictures of old Compressor Pump and new one for reference.
Also new pump stats PAG105 oil. I cannot find any info on that.
