1998 chevy cheyenne
JonTon209
I have a parasitic draw problem.. I disconnected the neg. batt. cable hooked up a test light and isolated it to the radio battery fuse in the fuse panel. I took out that fuse light went off. I dont have a owners manual so i dont know what else is on that circuit. cant figure out how to solve this please help..
Ironman1979
Odessa, TX
i think on that circuit the cigarette lighters the radio and maybe the amp if you have the bose system installed.
J
JonTon209
98 cheyenne
no bose system. stock steareo
SunlitComet
OBS Jedi-Do Good
unknown at this time.
The radio should have two fuses dedicated to itself only. One is the battery hot feed and the other is a switched ignition feed. If you have removed the hot feed one and the problem goes away there might be something wrong with the radio or something has been wired on that circuit that was not from the factory.
BTW:welcome:
pamelapanian
