07-14 Tahoe Low beam reflector outer dimensions?
kbuskill
NE. FL.
I am curious if anyone knows what the outer most dimensions of the low beams chrome reflector housing is?
Perhaps someone that has done a retrofit to projectors might know.
I was kicking around the idea of trying to install an LED "daymaker" style headlight inside the housing but I don't think there is enough room without major modification. The smallest daymaker style is a 5 3/4" diameter. I also thought about something like the 4" Morimoto LED fog light but I'm not sure if the output would be bright enough or suitable for a low beam application since the are for "fog light" applications.
Obviously the down side to this thought process would be if/when the light went out. It would suck having to open up the light to replace VS replacing just a bulb like a retrofit.
Any help or ideas would be appreciated.
kbuskill
kbuskill
NE. FL.
So no one has ever bought and installed halos that would know what size halo they bought???
fiatdale
Houstons Best
Houston
I had a set of aftermarkets with Oracle halos I sold on here years ago, but never measured the size.
Buzarr
