22" Max Tire Size? Need some help.
WillieFlo
Houston, Tx
Anyone running 285/55R22 's with a 2.5" level/lift on here? I'd like to see photos and or hear feedback on rubbing.
02Burgundybeast
South GA
I am. I have the rough country 2.25" front level, stock rear. I do scrub when I have people in the back and flex the rear. My truck 99% pavement so I rarely scrub. The front does rub and required minor work with the heat gun. I really like the look and the how the tires fill out the wheel well.
WillieFlo
Houston, Tx
Gents, I really like the way 0 or -# offset wheels look, INSTEAD of positive offset wheels. I plan on getting the Susp MAXX 2.5" level lift and will install 285/50R22 Terra Grappler G2's on Vogue VT379 wheels in Satin Black with +16mm offset, INSTEAD of the +31mm OEM offset.
Will pushing the wheels out that 15mm cause any rubbing at full lock? Anyone have experience with this? THANKS!!
WillieFlo
Houston, Tx
02BurgundyBeast, can you post any pics of your setup from the side for me? I'm interested in seeing how it looks.
jackedupZ71
anyone ever get any pics? I have been looking at replacing the tires on my wifes tahoe, and can't figure out if i can do a 285/50, 285/55, or stick with 285/45r22. the front is leveled, just haven't measured to see exactly how much it is raised up
WYO-HD
What is the biggest Nitto tire size I can go with on stock 22" rims with stock truck
285/45/22 is oem
but can it fit.....
305/45/22?
or
285/50/22?
or
285/55/55?
Would like the 305/45/22 to fit but unsure? Any input or thoughts would be great, thanks
305/45/22 on mine, for now, with no leveling or rubbing - stock ride height.File0_027745_800600.jpg File0_058752_800600.jpg
emerscape
Did you end up having to replace your spare tire or did you keep the same spare tire size when you went to the 305s? I'm trying to figure out if I need to replace my tahoe's spare tire as well.
jerry455
