Are shock extenders or aftermarket shocks needed W/ leveling kit?
187Import
Raleigh, NC
I was just wondering if shock extenders or aftermarket shocks, i.e. Bilstein 5100's are needed or recommended with the use of the CCM 2.5" leveling kit? I enjoy the excellent ride quality that the Yukon's, Tahoe's, and Escalades have from GM and I'd like to maintain that with the leveling kit. I just wanted to get your thoughts & opinions, thanks for your time.
01Konvict
Boats n Hoes
Raleigh/SML
No you do not need shock extenders for the front 2.5" level kit. The spacer goes on top or bottom of stock strut assembly. I prefer 5100s over the stock shocks though
187Import
187Import
Raleigh, NC
Thanks for your input, I appreciate it. I'm sure that the Bilsteins improve the ride quality just a hair :gr_grin:
UAV2007
IL
New to the forum and had a quick question regarding the CCM 2.5" Level. I have everything installed but after I pulled the strut out and mounted the spacer bracket, I noticed I had reinstall the strut 180 degrees from the way I pulled it out due to the new bolt "pattern" that is on the CCM spacer. Is the stock strut assembly designed to install in only one direction? Should I have swapped the passenger side strut with the driver side strut?
01Konvict
Boats n Hoes
Raleigh/SML
Don't know that kit off the top of my head but check both parts to see if there side specific. I doubt they are so just need to rotate the shock. It doesn't hurt the strut if you rotate it or not. Just line it all up and enjoy.
UAV2007
IL
Thanks Konvict for the information. I assumed the strut could be rotated but just wanted confirmation.
Zed 71
Pacific NW
No need for the front struts since that is what the spacer is essentially doing. However if you want to maximize the flex in the rear a longer shock is optimal like the 5100s.
dmarkellos
