Which grease for yolk & chassis; and which t-case fluid for '98
Jerky Arm Ape
Jerky Arm Ape
North East Louisiana
get that crap out and put in the autotrac because you said you have that t-case installed.
I let it drain over night and filled it with the auto trak 2 fliud which was dark blue in color.
I'm going to read through my Haynes Manual and see if there is a way to test the fluid pump.
Other wise I will continue to change the fluid until it begins to drain out with out any of the red stuff being mixed in with it.
ccapehartusarmyINF.(ret)
Gilbert AZ
every previous 4wd drive ive owned has always used ATF now theyve always been fords
though are these transfer cases on the newer tahoes a bit different then the old new process or borg warners ive had in the past
Jerky Arm Ape
Jerky Arm Ape
you cannot test the pump really. if the t-case does nit destroy itself then the pump is working really.
Well that's a sucky way to find out. It works fine so I guess I won't worry about it.
Just don't have a clue about how long ATF has been in there.
My truck has 237,*** miles on it.
Woodse
Do the nickel plated yoke if you have the clunk. Sunlitcomet sent me to Fort Wayne Driveshaft for the replacement. What a difference, no clunk! I wasted a year and greased the yoke three times which lasted a few days.
Busynesa
