persistent
- Joined
- Nov 10, 2023
- Posts
- 8
- Reaction score
- 14
i've recently taken over maintaining our family 2020 tahoe 6.2L 4x4 premier with 72k miles, and i am preparing to repair a leaking front differential pinion gear seal and change the fluids on the transmission, differentials and transfer case. however, i am having trouble nailing down exactly what drivetrain components i have in the vehicle. the transmission and transfer case fluid depend on which transmission i have, and the rear gear oil depends on which rear differential i have.
based on what i've read online, the 2020 with a 6.2L engine has the 10L80 10-speed transmission, which takes dexron ULV fluid. i have used a couple vin decoders and one said i have a 6 speed transmission and another said i have a 10 speed transmission. since the 6 speed takes dexron VI, i need to be certain which transmission i have before i order the atf. similarly, i see in the service manual i have that the rear differential takes either 75W85 or 75W90, depending on which size you have.
i would appreciate any assistance in figuring out which transmission and differentials i have in this car so i can get on with ordering parts for this work.
