vLED fogs, reverse lights and license plate lights
sixpointoh03
Would the 5k led fog lights match good witht the factory HID headlights in the denali?
S
Steve1081
Stock should be 4300k which is what I have; so, the match should be about the same as you see in my pictures. Which I think is pretty good.
sixpointoh03
Sweet I think I'm going to have to order me some
sevTahoe
Fogs and plates are on their way! Looking fwd to installing them.
Anyone know if the regular (non HID) headlight bulb could be replaced with an LED? The reason I think that one is different is because it doubles as the DRL on the LS and LT models of the Tahoe (same bulb, but glows more dimly as a DRL). Would love to replace that bulb so that it's a brighter DRL and a purer white that matches the LEDs and the incoming VLED fogs.
S
Steve1081
Generally the replacement LEDs do not have enough light output to replace a bulb you actually need to see with (high or low beam).
sevTahoe
Bummer, but not surprising. Thanks for the helpful post.
hosseface
Nice!
I installed some Sylvania 194 LEDs in my license plate lights.
If Sylvania would finally come out with some 912/921s I would love to have a set for my backup lights.
S
Steve1081
The vLEDs are very high quality and much brighter than the Philips LEDs I tried. Probably brighter than the Sylvania too.
You should give them a look.
Richard A
