Dryfly
- Joined
- Dec 30, 2012
- Posts
- 47
- Reaction score
- 0
The steering on my 99 Yukon has been loose and wandered quite a bit since I bought it last year. I attributed that to the front suspension being worn out at 170k miles. Also that I had the piman replaced so it was out of alignment Today, I had the upper and lower ball joints, and tie rods end replaced with Moog Problem Solvers, new tires, and an alignment. The steering is still pretty loose and seems like I have to correct more than I would like. Also it's easy to over-correct. The steering wheel is almost centered whereas before the alignment it was centered at about 2 o'clock. Now it's at about 12:30.
i understand that there are different steering boxes that I could put on this to make the steering not so "easy". Is there a way to tell which box I have, or perhaps I have the medium and it's worn. If so, can the box be rebuilt, or am I way off on this and should be lookin from a different angle?
Any help is appreciated.
