Brake lines ? SAE, Metric, or what ?
HDRock1
Flint,Mi
I'm not sure I picked up the right brake lines.
What I got are called Domestic
HDRock1
HDRock1
Flint,Mi
3/16 line goes across the front, from the left ,just under the evap can to the right wheel.
The ones I got say American thread, standard flare
I didn't take old one off yet.
My main concern is about the fittings on the end of the lines
SunlitComet
OBS Jedi-Do Good
unknown at this time.
when you cut the old line out put the old fittings on newly shaped tube before flaring the ends.
---------- Post added at 12:56 AM ---------- Previous post was at 12:55 AM ----------
or you can buy new ones. gm 15720627
Monzter Mike
Pittsburg, CA
If your lines are 3/16", they will be a double flair with a 3/8"-24 thread size flair nut. If your lines are 1/4" the flair nut will be a 7/16"-24 size nut. The only place I can think that the flair nuts would be a different size at would be at the master cylinder. I haven't ran new lines to an ABS controller, so those could be a strange flair nut size like the master cylinders. GM didn't use metric lines on trucks till they went to the new body style Tahoe in 2006 & new body style truck in 2007.
HDRock1
HDRock1
Flint,Mi
All right ! double flair with a 3/8"-24 thread size flair nut, good info, thats what I got.
kevinsbritton
