adventurenali92
Big Bear Lake, ca
Y’all are funny on the headlight clearing topic and about it being tedious. I do headlight restorations on clients cars all the time and its such a simple and easy process…. Well if you have the proper tools and product on hand lol.
adventurenali92
Big Bear Lake, ca
Opened up the front and rear diffs last night to drain and refill with fresh fluid. Popped the rear diff cover off and the factory gasket started working itself apart. Thankfully I had a new fel-pro gasket in the garage that I’d bought from the last service that I didn’t need to use last time to replace the end of life factory gasket. Got it all buttoned back up and then took off on a 300 mile road trip today.
Roilux
Burbank, CA
Replaced LF wheel hub and oil pressure sending unit. I'm chasing a small oil drip and the area around the sending unit is, well, a touch moist. If the small drip persists I'll replace the oil cooler delete plate during the next oil change in hopes remedying the drip doesn't become more involved.
DieselDean
