stretchb1953
- Joined
- Jan 27, 2024
- Posts
- 22
- Reaction score
- 38
ok all. replaced the oil pressure sensor and screen. did my leak check and function check. oil pressure is still about 20 PSI at idle. man it was a pain to change but got it done. next question is, what's next? and hopefully it ain't an oil pump.Got a new problem now. New code P0521 oil pressure. went and got an oil pressure sensor and screen. picked up the tahoe from stepdaughter's work and drove it home. pressure indicate less than 20 psi at idle but climbs to about 30 at 60MPH.. got home and tried to access the POS sensor and found it buried under a plastic panel. how the heck do you remove that panel, shgrt of a dremel tool? and what is it there for? am starting to wonder what other codes are gonna start popping up one after the other.
