Project Workshop
- Joined
- Nov 17, 2021
- Posts
- 55
- Reaction score
- 146
Sorry this is a really long one, hoping for some advice.
1. The Stabilitrack issue.
First the backstory.
Received my front coilovers back from Accutune and installed. Tuner and I are happy with the installed shock and spring length with the 600lb springs.
Installed the rear Dobinson springs (C09-037) and Fox DSC rear shocks. Suspension feels dialed, I am very happy with the new setup. Accidentally unplugged one of the rear wheel speed sensor cables so caught a code when I started it up. Plugged it back in and all was good.
On Wednesday got an alignment. Picked it up and ABS Service Stabilitrack message was on. Had to pickup at closing time but had an appointment to return on Friday to swap the steering rack which was showing its age.
After the steering rack install I asked again if the steering sensor had been calibrated. Tech swore the code was due to the wheel speed sensor that needed to be replaced (code showed passed since plugging it back in).
Got home plugged into Tech II The code reads C0710 and the Steering Wheel Position shows -360 when the steering wheel is straight. When turning right the number goes towards 0 with no problems, however when turning left and the number passes around -400* throws a Stabilitrack code instantly.
I will be going in to the shop tomorrow to speak with them again, but was wondering if anyone has had experience with this? Also if anyone happens to know the proper Steering Wheel Position degree when wheel is centered? I am assuming 0* but would be great to have confirmation.
2. Passenger Airbag issue
I have been dealing with an Airbag light on and off for the last couple of months. First started on a mild offroad trip after hitting a bump in the trail. The code comes on and off at random ever since.
Originally I was using an inexpensive Autel unit and received the following codes B0081-0f and B0081-71 so I assumed the passenger presence pad was faulty and replaced it with a used unit from Ebay. Still dealing with the code I finally purchased a Tech II.
The interesting thing is the Tech II shows a completely different code, B0071 Symptom 7. This now indicates that the Passenger Seat Belt Tension Sensor may be the culprit. I unplugged, checked and reconnected the plug I believe to be the the 3 wire potentiometer. I don’t know where to start with this one.
I apologize for the lengthy post and sincerely appreciate any advice you can give me.
