Want to take my 2010 Yukon XL Denali with 180,000 miles for a family trip from Michigan To Florida - Can you help me make this a success!
bobby2175
Hi Everyone,
I'm not a mechanic, but starting to do some very basic things on the truck to fix some random issues.
I'm the original owner and have kept up generally on all maintenance. The last major maintenance took place around 120K miles where I had the GM dealer do their typical 100K mile service.
The only major issue I've run into over the past 5 years is the electrical issue that's all over the internet and this forum with gauges acting up, no start, under powered engine, etc. I've gone through and replaced the battery, battery cables, cleaned up/replaced the ground wires, and fuse block under the hood and now am about 800 miles in with no issues!
I have a few concerns:
1. I believe there is an engine oil leak (I have to top off oil to get to my next oil change - about a half bottle) and there is definitely evidence of it in the engine compartment
2. Someone mentioned years ago that I have a differential leak (have not done anything with this).
3. I can feel at idle that the car isn't fully smooth - I can feel a little bit of "shake" during idle (sorry, not sure how to describe it)
4. When I hit the gas, the truck hesitates for a split second where it feelslike it hits gear a little hard (gear is a complete assumption). If I'm gentle on the accelerator going from stop, it's perfectly smooth - but even knowing this, sometimes I forget.
Other than these issues (which up until now when I'm planning a long trip), I'd considered nuisance items. The vehicle itself runs great and I'm often traveling between a couple of states - think 2 hour drives each way a couple times a month and it's always an awesome drive and I'm never worried about it.
So, what should I address before I hit the road? I'm also afraid to do too much (like a trans flush) and run into issues on the way?
What stuff should I pack with me like extra fuses, jumper cables, etc to solve an issue in a pinch?
Thanks for all of your help. I really appreciate it!
Bobby
well, it really depends on what all has been done already and how much you are willing to spend
transmission aside
I would replace the heater hoses and "T"'s (with oem) if they have not been done already
plugs and wires and clean the maf and throttle body
those item's above would be "bare minimum" in my suggestion box
B
bobby2175
transmission aside
I'm willing to spend some money - my hope is to push this truck to 300,000 miles if possible, so I'm not only looking at this as an investment for the trip, but long term as well.
I have not done any major maintenance on the truck other than what's mentioned above.
I haven't looked at it yet, but will do some research - is this something a non-mechanic with very, very basic vehicle skills can handle, but willing to research and learn?
I haven't looked at it yet, but will do some research - is this something a non-mechanic with very, very basic vehicle skills can handle?
yes for the most part, the heater hose t's on the firewall tend to be a headache but the easiest way is to cut the old ones off with some long needlenose pliers, there is a tool to take them off but it can still be difficult since you have to push and pull while applying the tool at the same time.
the #8 spark plug tends to be hard for some people but if you use your brain and a couple of adapters it's super easy.
the rest is a walk in the park.
B
bobby2175
Thanks! I'll look at this - I've not done spark plugs before (on any vehicle) but have started researching it and have seen the comments on #8.
You mentioned a couple of posts up - "really depends on what all has been done already and how much you are willing to spend" - should I consider anything else since I'm ok putting money into the truck?
some other things would be
serpentine and ac belt
flush all fluids power steering, brake, coolant (while doing the aforementioned hoses), front & rear diff, transfer case.
@180k on original transmission?
how old is the battery?
B
bobby2175
Yes, original transmission and I replaced the battery at the end of 2021.
Do I need to think about anything on the transmission?
That's a great list - any of those fluid flushes things I can handle myself? I was looking at the belts the other day when I was working on electrical stuff and wondering if I could do it, but it looked pretty complicated.
What all was done at the 100K service? If the plugs were done, I wouldn't worry with those with only 80K on 'em. The OEM-spec platinum (or iridium, if used) can easily go twice that long. I'd definitely look at the "soft" parts Wes listed out. Don't overlook the simple basics such as tire pressures. Check the pressure of the spare and its condition. The spare is all too often forgotten about.
Bobby, I've been doing the same thing. Getting my 2009 Yukon XL with 191K ready for a trip from Florida to Monument Valley and back.
Your number 3 and 4 is probably because your driver's side engine mount is broken. They are fluid filled and only last so long under the power of that glorious 6.2.
If you have external engine oil cooler and transmission coolers, make sure the lines are not leaking. Sweating and weeping is ok, leaking is bad. Engine oil cooler would be lines going into driver's side tank on the radiator.
Fresh fluids will make the truck more efficient. Your "To Do" list can get out of hand and you can still have an alternator fail or radiator tank crack so don't worry about much under the hood if she's running well. In our case, we have enough set aside to leave the truck at a shop for a transmission overhaul while we rent another Yukon XL and continue on with our trip if necessary.
I did replace my heater hoses and Ts, even bought the tool to remove them but discovered it was not necessary with a firm grip and the push/squeeze/pull method. Popped right off.
Unlike you, I'll be using washer fluid that won't freeze and made sure my coolant mixture can handle freezing weather!
What part of Florida are you headed for?
Hi Everyone,
Bobby
You have received great advice from the knowledgeable folks on this Forum.
If you have a local shop in your area that you trust, you can have some of these recommended maintenance items done for a much lower cost that going to the dealer.
Check all fluid levels, particularly the differential (which you said may have a leak).
Change ALL coolant hoses, including the 2 Tees, as mentioned above. (I had a coolant hose rupture on my Denali, and the coolant was pumped out on the road in a matter of seconds.)
BlazinMilk
