Mean_Green
- Joined
- Mar 23, 2023
- Posts
- 390
- Reaction score
- 523
Which is what he's trying to avoid.They draw so little current they need to be canbus compatible or you will get a “bulb out” message.
What year truck are you driving?These are by far the brightest 921 LED reverse bulbs I’ve used. It does say that they are “canbus error free” in 98% of vehicles.
Error Free 912 921 LED Bulb Extremely Bright CSP 9-SMD Plug and Play for Backup Reverse Lights
921/912 LED backup reverse light bulbs: about 2000 lumens each bulb, color temperature: 6500K. Bulb bottom diameter: 3cm (1.18in), wire length: 3.6cm (1.41in), bulb body height: 4.85cm (1.93in)www.auxito.com
They made a noticeable improvement on night time visibility that is also noticeable in the backup camera.
thanks but I’m looking for a tried and true solution. I don’t want to spend money on something only to find out it doesn’t workI’ve installed them in a 2013 Escalade ESV as well as a 2015 Yukon XL Denali.
I know either vehicle is a 21+, which is why I mentioned they are “canbus error free” in 98% of vehicles.
These sites are very informative for a whole host of issues. The crappy rear lights in the 21 plus Tahoe and suburbans are the single biggest complaint that everyone has. In the previous gen I put leds in the back ups without issue and the rest of the lighting was more than adequate and very aesthetically pleasing.I understand.
Here are the same bulbs I linked above on Amazon and for a quite a bit cheaper!
I'm sure if you installed them as soon as you plugged them in and turned on your vehicle you'd know if they gave you an error message or not. If they do just return them pretty easily through Amazon.
The error message you speak of is the exact reason why they started offering canbus friendly error free bulbs. Read the reviews one user reports having them installed in a 2022 Silverado Trail Boss, 2021 4Runner, 2020 Silverado 2500 HD all with no issues.
That's one of the options I was thinking of. They also sell (or used to sell) a Cool Blue halogen in most lamp styles. Looks like the 921 is still available. They're as close to LED high white as I've seen.Ive bought a set of sylvania silver stars in 921. Hopefully it’s better.
I’ve used the silver stars in my headlights. I was partial to Piaa’s thoughThat's one of the options I was thinking of. They also sell (or used to sell) a Cool Blue halogen in most lamp styles. Looks like the 921 is still available. They're as close to LED high white as I've seen.
SYLVANIA 921 Long Life Mini Bulb, 2 Pack
SYLVANIA Long Life miniature bulbs provide standard performance for your car or truck's interior and exterior auxiliary lighting. Ideal for use in your car's back up/reverse, trunk, dome lights and more, Long Life bulbs are a direct replacement for your vehicle. Designed for durability, lower...www.sylvania-automotive.com
I used Cool Blue 9005 and 9006 in my headlights.
