A/C evaporator replacement 98 Yukon
olliec420
So on my 98 (C60 front a/c only) I have been charging it up repeatedly since I got it. I knew the service port valves were leaking and I ordered them a while ago but I never put them in. Well I was going to do it some weeks ago but before I did I thought to myself I really outa get a leak detector and make sure that's the only place I'm leaking before I start making moves. Well I put the detector inside the cab near the evaporator and that thing was beeping like crazy. The part I really didn't want to fix.
I watched some videos and saw how to get access without dash removal so its not bad as I thought it would be. But while I'm in there, what all should I be replacing. Here is the list I have so far:
1) low and high service port cores
2) accumulator/dryer
3) evaporator
4) blower motor
5) resistor
6) heater core?
What am I missing? Thanks!
Multnomah Falls
Military
Yes on the heater core, especially if original and how old are easily accessed actuators? Do the orifice and flush lines and condensor.
olliec420
olliec420
Thanks for the quick response! Im on rock auto putting together the cart right now.
I wasn't going to get in to the orifice and condenser if I didn't have to. When its working as it is, it works great. But the blower motor squeaks a bit. But I see the orifice is cheap. Will I need the tool or can I use needle nose?
The actuators are what? Heater air door actuator? Thats the only one I see.
east302
Mississippi
Just curious, do you have a link to that video showing the evaporator removal without pulling the dash? Seems like you’d have to cut the box open or something.
If you’re going in with the dash in, note that there’s a screw holding the line in place and also a condensate trap/screen that’ll need to be swapped over. Also some rubber gasket along the evaporator face that’ll need to be reused or recreated. It usually tears apart whenever I’ve tried to salvage it so trimming some weatherstripping from a big box store is usually in order.
There are three actuators - the heater (mode), the blend door by the gas pedal and the recirc door actuator tucked up above the blower.
Pulling the dash isn’t that difficult and would let you get in and replace the air box dampers. Their rubber edges usually dry rot and you get air leaks.
Here’s a link on the dash removal, maybe it’ll help if you go that route. But, if you have any cracks in your dash I’d be hesitant to pull it since it’ll flex when it comes down.
olliec420
olliec420
I only saw one on rock auto. I ordered it. I just thought about it but no matter what settings I'm on some air comes outa defrost vents. Do you know the name of what actuator or door would do that?
Yeah I got cracks and when I got it there was major problem in the front end and everything was getting shaken to shit and did a number on that plastic. The previous owner drove it like that. I fixed all that now and now this. I sure hope this is it for a while.
Multnomah Falls
Military
If is easy, do the actuator, no matter which one. I have used needle nose on the orifice when the tool would not work but the tool is inexpensive to own, or maybe get at a auto parts store. The tool is useful for the install as well and make sure you use a/c oil to lube the seal before the install.
I typed this earlier and forgot to post it.
east302
Mississippi
Thanks for the link, I’d just figured there was no other way to get to that evaporator. If the dash is already rough, then it’s worth a shot.
The blend (heater) and mode (floor-dash-defrost) actuators are the same. The recirc would be a different part number.
The way the box is designed, there is always some air flowing into the side defrost vents regardless of vent setting. The air bypasses the dampers through the small port in the lower left. The one above it is to the dash defrost vents and the one on the right is to the floor and panel vents.
If the air isn’t adjusting to the correct vent setting, then the actuator (by the gas pedal) is a good suspect. The floor damper arm connects right to the actuator, the other two dampers connect with the linkage arms.
The actuator has a silver notched dial on it. Watch it as you turn it from floor to panel to defrost. It should turn smoothly between the lines on the actuator. The damper linkage arms should also adjust smoothly. Check to see that the linkages are intact. The silver arms at the top are connected to the damper shafts.
If the dial hesitates, jerks or makes a ratcheting sound, then the internal plastic gears are likely cracked and a new actuator would be needed.
If the above checks out and air is adjusting correctly but just leaking, then the internal dampers are probably deteriorating.
This photo is an old vs new floor damper but the other two have similar rubber edges. You can see where the perimeter seal disintegrated so air went right past. The dash definitely has to come out to replace these, unfortunately.
olliec420
olliec420
Thats helpful. Making me not want to take this apart and sell it. lol
Eman85
Never had to replace an evap core on those, not common. If I was going to replace the evap core and I hadn't replaced the compressor I would go ahead and replace it and be done with it. Compressor is the most common point of leakage and the weak link in the system. You'll know more when you pull the orifice tube as that's where you'll find all of the worn internals of the compressor. Be sure to flush the condenser and add the correct amount of oil back.
olliec420
olliec420
The compressor seems to work great. Its not OEM, its been replaced at some point. Maybe the previous owner changed that and then found out it was the evaporator and just sold it.
Bubba6
