Jeff53
- Joined
- Jan 28, 2023
- Posts
- 96
- Reaction score
- 156
Engineer A: OK, guys, we need to come up with someplace to put the ABS control module on the new GMT800.
Engineer B: I know, let's put it under the hood somewhere where it will be somewhat protected from the elements.
Engineer C: You fool! Do you want to make it easy for the owner to service it if it's necessary? What's wrong with you? Here's an idea....let's put it on the frame under the driver's seat where it can get lots of road debris and water on it? And, also, let's make it hard to get any type of tool in there to remove it!
Engineer A: Sounds like a great idea. Oh, oh....I have an even better idea! Let's use tiny T20 Torx screws to mount it! That way, when the screws start to rust at some point, it will be almost impossible to take the module off and service it...they'll never be able to get a good grip with a T20 bit on those tiny, little screws!
Engineer B: But, shouldn't we consider things like having to service a part and try to make it easier for the owner or their mechanic?
Engineer A and C simultaneously: Shut up you idiot. We don't care if it's easy to service! Besides, what could go wrong with mounting a sensitive electronic device under the vehicle...ha, ha, ha, ha, ha, ha, ha!!!!!!
