Hello all, newbie to the forum looking for help, trying to change upper control arm, nut side broke off in bushing was going to sawzall it off and get a new bolt but wanted to make sure I dont damage the brackets on the frame. Ive read to pry the bracket away enough to get a sawzall blade thru to cut the bolt inside but I cannot get my bracket to move enough to get a good look at the bolt. I cut and ripped away the rubber bushing and was just going to sawzall thru directly below the rubber layer, will this work? On the picture i uploaded the red circle is where i peeled away the rubber and planned to cut, the blue circle is where im wondering is this protruding circle part of the frame bracket or part of the control arm that is jusg so corroded/ undercoated that it looks like it is part of the bracket.
Thank you so much for reading my long post and any wisdom y'all might share to guide me along!
