2008 LTZ Suspension upgrade advice
JayYoung
Georgia
Greetings all.
I have a 2008 LTZ Tahoe, 185,000 miles, on stock suspension. After spending way too much money on this 5.3, its behaving very nice, and ready for another 100,000 miles. Now I need to address the suspension.
As far as I know, I do not have magnaride, air, auto leveling, or any other electronic wizardry. I would love to have all of that, but I'm not sure its feasible to retrofit. I am seeking advice about the best quality update for my needs. I spend 20% of my driving time in fields and off-road areas. I routinely haul 1000lbs in the back, rarely tow anything. I am looking for the most comfortable ride quality I can achieve. I would like to reduce the harshness of poor quality roads, make the steering slightly more responsive, but also have a system that will last with proper maintenance.
Is it possible to add magnaride/autoleveling air suspension to a 2008 LTZ in which it was not installed from the factory?
Is it prohibitively expensive?
Is there an alternative?
Very willing to hear options and opinions.
wjburken
Eastern Iowa
Greetings all.
Post up a picture of your RPO sticker. Should be on the door if your glove compartment. It will have a bunch of 3 letter codes in it. That will help us help you determine what your LTZ has for suspension for sure. I am thinking that the LTZ’s came with AutoRide and AutoLevel. At least my 2009 LTZ did.
Trey Hardy
Eastern North Carolina
Greetings all.
How much you trying to spend?
I love the ride of my uniball uca helps a lot over bad bumps
My ball joint wheel bearings sway bar links and tie rods are kryptonite and are also really like heavy duty with lifetime warranty
Shocks will be where you see the most difference and it’ll be most expensive
Best and smoothest riding will probably be king coil overs
Next for a nice ride and somewhat cheaper is fox coil overs
I have icons there nice but might ride stiff to some people but I like it as to me it feels more controlled over bumps and curves whoops and all
Look to spend 2000-3000$ give or take I did all my stuff myself it was pretty easy to be honest then go get a alignment
Geotrash
Dave
Richmond, VA
Here are the codes as requested. @wjburken
Unfortunately your understanding is correct that you don't have the autoride or autolevel suspension. ZW7 is premium smooth ride which means yours has conventional shocks and springs. The bummer is that you can't easily add the factory autoride/level components, but the good thing is that you can upgrade to a better conventional setup without having to disable the automated system in the process. Lots of good threads here on how to do that, and Trey is offering some good input above also.
steiny93
Greetings all.
I have a 2008 LTZ Tahoe, 185,000 miles, on stock suspension...
I have an '08 LTZ lifted on tracks, same suspension as yours; my build was 100% clearance (I can't have the tracks hitting the fenders) no consideration for ride quality.
Listening to your comments, I'd vote you figure out a full solution (coil overs / shocks / probably replacing a pile of worn bits) and decide if its really worth the effort. You're going to get a pile of cash into a suspension that you will never recoup. Could you get away with replacing some worn bits and maybe a medium upgrade to the shocks to get you far enough down the road and save some cash?
200k suspensions can continually consume cash
J
JayYoung
Georgia
Thanks for all the replies. I think perhaps the best option is to replace all the warn bits, and upgrade the factory shocks/struts. I will take a look at the King / Fox setups, thanks for the advice there. I really just want to feel less bumps. While I would have loved to retrofit the factory magnaride option, I do understand that would be quite a large undertaking, and not worth it in the end. If I ever trade trucks, I'll be sure to get those options already installed.
jodinchris
