Front Dash Crack
Brooklyn hoe
Thanks, it was easier then I imagined. Tools needed where 10mm and 7mm sockets also a pry tool. Scariest part of replacing was removing the air bag. As for reinforcing the dash I used 1 can of plasti dip.
Brooklyn hoe
Oh Yeah almost forgot. When taking out the bolts you can use a drill to make it go faster but when you are installing the new one, hand tighten if not the bolts will snap.
Doug118
Just swapped my dash. Took a hour and 40 minutes to from start to 98% complete. Just need to do the airbag and the front piece of the dash (ran out of daylight)
Letcher77
Apologies if this has been asked. But once a skin is attached, does it obscure any of the attachment hardware? In other words, if you ever have to remove the dash, do you need to plan on purchasing a new skin (or new dash)?
Just FYI once the dash skin has been attached you are unable to remove the gauge cluster without having to remove the dash skin.
Letcher77
Can I ask where you got the replacement dash and how much it cost?
the_tool_man
Upstate South Carolina
What's the button in your console forward bin for?
Or what’s up with the area of the dash where the stereo is supposed to be? Is that a giant cubby?
Also, is it only me or is the layout of this thread all messed up? All the posts are in a narrow sidebar.
992dr
N.C.
It's not just you. The formatting is really ******* up.
I thought I was losing my mind.
Hell, it took me a while to find where/how to post haha
Jmily8474
