20" Sierra wheels on a NNBS
LRob
Does anyone have these on their truck? I'm thinking about going this route but have never seen these on our Tahoes. If you have a pic, please post up!
L
LRob
I have no idea the offset or name of them.
I'd guess that the offset is the same, or very similar across all the GMT900 20" wheels. I don't have those particular GMC wheels on mine, but the ones I have are from the same generation and they fit just like my stock LTZ 20s:
Same wheels, de-cladded:
Geoffsfas10
St. Louis
Im curious about this as well, they are good looking wheels on the trucks but not sure how theyd look on the tahoes.
As @Fless stated, check the numbers stamped on the back of the wheel. The 'X**' portion of the numbers is the important number. If it is X31, then it is a 31mm offset, which is stock for the 20" wheels, and it should fit.
Most of the GMT900 wheels have a 31 mm offset, the CK213 and CK805 have a 22 mm offset and CK925 and CK997 have a 27 mm offset.
Interesting. So, "worst" case, the wheels will sit out 9mm further at most. Well, assuming the 20" wheels are the same width.
Paulgeyer
