just wanna cover the threads, it does come with a cap but that is just for shipping purposes so the thread don't get damaged. just slides on top of the threads, and held down when the lid of box is closed.
Mine is a Gates and came with a ****** of sorts. It’s just a rubber sleeve.
eohat
In Torque We Trust
Mike @ Altitude 5,280 ft.
I swapped the wheels on the 04 & 05 the other day and the 05 oem wheels needed 1 tpms sensor and a couple tires so I went and bought a couple used tires and had them do the 1 wheel that needed a sensor, relearned the tpms and drove down the road, and sumbitch tpms goes off again, so I relearned again drove down the road some more and dammit tpms lights up again, so I did the relearn again, got home and the tpms goes off again, so I pull out the tech2 and and fiddling around finally found the tpms info and the 3 old sensors were only reading 21 psi :mad: the new one was reading 44 psi which is what the tires are inflated to. I tried changing the tire size/psi to something in the middle like 30 psi and deflated the 1 new sensor to 38 psi but it just wouldn't work so I ended up have to buy 3 more tpms sensors :nono:
When one goes it’s usually the battery so the other are right there too. I just buy all 4 unless they’re fairly new.
The Beast absolutely destroyed the front diff, guess it didn’t like a WOT launch from a stop in reverse. Snapped a CV joint on the driver side and most surprising was it snapped the passenger side axle tube, cracked that mofo all the way around. Ordered a rebuilt diff and both CV axles.
BF463948-605C-40A5-828F-482A09D0AE6A.jpeg EA9F83E0-BD19-4CAF-88D0-BFAEE826AC43.jpeg 6D81A446-A8C8-411F-880E-78F7F91BD789.jpeg 41AC395D-23F6-4649-B4F6-2C4ADA7056DC.jpeg
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
View attachment 257359 View attachment 257360 View attachment 257361 View attachment 257362
Surprised you did't catch the carnage on video likes others @Tonyrodz, lol. Oh what i for got @Tonyrodz doesn't do stuff like that.
imterarizer
