I do believe the 01-02 RPO code differs from 03-06. I could totally be wrong(it’s happened once or twice lol)
It doesn’t really matter as it relates to SEM paint. There’s nothing, zI repeat....NOTHING that SEM uses to cross-reference their color codes to GM’s interior color codes- believe me, I have looked. And looked. I tried when painting the interior of my 02 Denali and again when painting interior ( in something as simple as black) in my 08 Silverado. There’s zero cross- references. 92I/ 922/923 mean nothing to SEM, and the SEM numbers mean nothing to GM. It’s like they don’t know the other exists. :crazy::crazy::crazy::crazy::crazy:
replaced the airbag sdm module (black box) on the 04 today and a couple window switches on the 05, the "service airbag" message has been on the dam thing for 2-3 years, dealer wanted $650 to replace it and I was too lazy to pull it out and send it off to some joker to have it reset, come to find out you can just put in a used one that was not in any accident and reset it to the vin with the tech2 and walla, easy-peasy
I did that on my Silvy but in the end it was a wire with a break.
HiHoeSilver
Away!
Chicago
on this one I knew it was the module for sure, she rear ended someone about 3 years ago I replaced the airbag and fixed the front end, the b0055 code (i think) won't reset and the dealer wont reset it because of legal reasons I presume I guess if you were in a serious accident and killed someone and the dealer reset it for you then it would be tampering with evidence or whatever.....
so the solution is to replace it or send it out to have it done and sent back. Tech2 pays off again
Oh yeah, I remember seeing the eBay sellers that advertised to “reset” the SDM so that’s what I figured it was. Send your module in, they reset it and send it back. I was hoping for a small miracle when I programmed a used one but I ended up figuring which wire was open. There’s a lot of wires in that damn harness. Anyway it wasn’t a bad SDM.
You made that look easy--messing with that Tech 2. Do you need a subscription to be able to program your vin into that module? I saw the candi module on the seat.
treehan77
TYF Fiend
Crestview, FL
Finally replaced the driver side blend door actuator that I’d had sitting for 4 months. 3 years ago it turned hot once, I took it apart and cleaned etc. worked fine until a couple months ago, it did it once. This week it happened 4 times, so in the new one went. Old one still clean this time, the contacts weren’t green and gooey this time under the black gear
no subscription, as long as the module has not activated any airbags (just used) then the tech2 will reset it to the transplant vin, it was super easy, at the junk yard I didn't have the option to move a seat back and forth, but I found a 05 tahoe that wasn't smashed anywhere and the seat was back far enough to unbolt the 2 front bolts, so I took those out and bent the seat back as much as I could, cut the carpet and padding around the module and i had enough room to pull it out, on the 04 I just unbolted the seat lifted it up and moved it back a couple inches, pulled the carpet up from the side and reached in with the 10mm didn't have to cut anything. The Candi module I just leave attached all the time.
Chuck 2015 Tahoe
