96-2D-Hoe
This is the one by the crank sensor and balancer?
Yes. The ground for the crankshaft sensor is also on the stud. Need to disconnect the crank sensor connector and move the wire as it's in the way
It's basically the main ground off the battery. I've cleaned up most of the others but until I did this one it hadn't made much difference as the others were 'downstream'.
Battery terminal > Front engine block
Rear engine block > Frame
Frame > Firewall
is the flow and all the main grounds that I'm aware of. There are probably a couple more
Fedeleon1
Updates on the tahoe, full clean of the interior, the seats don't work, so they need to get fix, also the leather of the steering wheel is crap, doing a refresh there too, also I put on new kicker speakers in all corners and a 12" kicker subwoofer, the back speakers are 6x9s, we cut the plates to fit them, also the roof is sealed now, more water in.
More photos this weekend
mtl111
Arkansas
Awesome ! The pics reminded me of my 2 door. Gutted it down to bare metal a few years ago. Lots of work but it'll be worth it!
Sent from my SAMSUNG-SM-G930A using Tapatalk
96-2D-Hoe
Wish I had fluffy looking carpet. Same interior and color as mine. Enjoy.
mtl111
Arkansas
I had no choice but to buy all new carpet, the interior on mine was so nasty when I got it I felt like I needed a tetanus shot after pulling that mess out! Lol!!
TheAutumnWind
Painted my rusty roof. Wire brushed the rust. Hit with rust converter primer then sanded and painted with rustoleum turbo. Better than rust! Hopefully looks decent in the sunlight.
DH24YUKON
