For those that removed PPV suspension...
GranPrix
When changing to the base model suspension such as the struts and springs, did anyone also change the knuckle and lower A-arm?
GranPrix
GranPrix
Anyone know if the knuckles need to be swapped? Apparently there are two part #'s for the knuckles on the base Tahoe and the PPV...
I don't know but "generally" with things like that one may be a slightly different size than the other if you pull the part specs side then you can compare them and then compare it to what you have installed. Rockauto is pretty good at listing the details usually.
GranPrix
GranPrix
Rock doesn't have much info on them. So far these are the part #s I've come across that are PPV specific:
L Knuckle: 22760659, 1st design
L Knuckle:
R Knuckle: 22760658, 1st design
R Knuckle: 23242660, 2nd design
L A-arm: 84114507
R A-arm: 84114508
