Rough Country 7.5 lift Problems
scottbrew92
South AL
Had the same feeling with my Tahoe and the 7.5" lift I was even getting a traction control light in corners with a leaning feeling. I ordered and installed some "spherical" front sway bar links and really tightened everything up so make sure your front links are tight.
81malibu350
81malibu350
Long Island NY
Hi Guys.. I still haven't installed the pro comp brackets because i have been dealing with some other problems. i keep getting a check engine light with the codes of p2122 and p2138 i have changed the throttle body and the gas pedal and the connector on the tb.. Any help would be Appreciated!! Thanks
81malibu350
81malibu350
Long Island NY
Where did you get the end links from?
Lil_Stump
Brunswick, GA
Does anyone have the part number for the pro comp drop brackets? Or are they something id have to call and get special ordered seperately from their 6” kit?
01Konvict
Boats n Hoes
Raleigh/SML
You can order them from summit racing. Look up the kit instructions and get the part numbers. Or I posted them in a white burb thread that had the rough country 7.5 kit.
hipjunky
