Administrator
Ordered a Pioneer DEH-S6000BS today. Should be here soon. Not gonna worry about much more of the sound system aspect for a while but this will at least be a good basis for when I start down that road at some point.
My99Yukon
Finally got around to:
A.) swapping the 3.42 to 4.10 diff regear.
B.) Also, tore into the transfer case that was plaguing me for the last several months.
i found out that the old shop had installed some parts bass-ackwards which caused some parts to overheat, melt and fuse. No wonder the 4lo wouldnt engage. So with that, the only other item on my checklist is the MPFI which I hope to tear into this week before my next trip.
Administrator
Got the wiring harness wrapped up for the stereo in the 99
5E1E29EE-0D0B-4E13-A7A0-5C3B1D5A4EA4.jpeg 0354BC23-5C64-471B-A828-8C5BD233FD91.jpeg 3DAF133C-979B-4850-AC26-69432EA8820D.jpeg
99YukonSLT
Ohio
Recap over the last few weeks -
Flowtech Ceramic coated headers - done
EGR Delete - done
Replace all bump stops - done (minus one that was bad out of the box)
GM 05+ Electric fan install - done
Still need to get my LF axle seal & front diff fluid changed at some point.
ObsUkon
Yakima
Picked this up as a "mechanic special" ($500 140k miles) on CL, swapped out the fuel pump and replaced leaking intake manifold gaskets and related gaskets as well as water pump. Gave it an oil change, coolant flush, front and rear diff service, replaced front brakes (metal to metal), replaced inner and outer tie rods, gave it an allingment and balanced wheels. Will finish up the "Tune up" sometime this week. Runs like a champ as is. Had the front windows tinted to match the rest and installed my spare sound system. Ordered a set of Aftermarket headlights last night, led interior lights also on their way. Full detail coming up as soon as the guys at work can squeeze it in.
20180526_171514.jpg 548464895.jpg 548464826.jpg 20180509_145708.jpg 548464758.jpg
DallasTahoe
Had to use Project White Girl to tow my sons car into our 30 degree rear driveway since he totaled it yesterday...
fastpat
Upcountry South Carolina
Exactly what had they installed incorrectly? This info would be valuable as a check for inspecting the work of other shops.
Dlshort21
