jeff laing
- Joined
- Aug 3, 2017
- Posts
- 90
- Reaction score
- 83
Only went to the half mark.. it’s a 2015 Tahoe LTZDid the fluid in the reservoir get too low?
What year, model is your rig?
I have done both, but I do have a vacare you just pumping the peddle or vac or pressure?
I got it to work this morning, I used my old had pump and it started to suck the fluid.. Maybe yesterday was just a long day and I overlook something but this morning I had them blood within the hour! Oh well it’s done now!Also, I believe the Wildwoods require adapters and new hoses. Make sure there is nothing blocking either the hose or adapter.
I have used all three methods to bleed. As long as proper procedure is followed, there should be no problems. (I prefer vac as last time I used pressure, the hose developed a leak and got brake fluid EVERYWHERE. I was not real happy with my Motive, and mine was not of the best quality—flashing on the hose barb for the tank which causes leaks, the hose from the unit is horrible and got hard after about two years, etc. I expected better for what I paid!).
Take your time and work methodically.
Nice wheels...I got it to work this morning, I used my old had pump and it started to suck the fluid.. Maybe yesterday was just a long day and I overlook something but this morning I had them blood within the hour! Oh well it’s done now!
View attachment 196516 View attachment 196517
You must have got a faulty unit. I've had mine for a long time and bled many many sets of brakes. By far the easiest way to bleed. I absolutely couldn't stand the vacuum bleeders, they always leaked and you need a compressor to use them. I went through a gallon of brake fluid the last time I used one because it kept sucking air at the bleeder and I couldn't tell if the brakes still had air in the lines. If you would have used a vac on that leaker you would never have known where it was leaking because you would have kept pulling air in. After a gallon or two of fluid you'd still have air in the lines and been scratching your head.Also, I believe the Wildwoods require adapters and new hoses. Make sure there is nothing blocking either the hose or adapter.
