Battery Acts Dead but tests Good
Silent D
So first post, I did search and read for the last two hours can didn't find my problem.
I have a 2009 Tahoe LTZ, Canadian model, with stock battery. A few months ago, while driving all the interior power (lights, radio, etc) would turn off and the engine would die. I'd pull over and try to start it but it wouldn't, no slow crank-no click-noting at all. If I wiggle the + battery it would start. Then after a few months no issues at all. Now the last few months on occasions its been acting like it has a dead battery, slow to crank and won't start, volt meter reads 0-9 volts. I wiggle the + cable and nothing, jump start it and it fires up. While driving the volt meter reads about 15 volts charging. I had the battery tested at the dealer on the last oil change and they said the battery tested good with and without a load. I ended up putting it on a battery tender and the tender read 100% charged in about 15 minutes, no issues with it for a few weeks. I just took my wife to an appointment and while she was inside for about 20 mins the Tahoe was off and I listened to the radio. It wouldn't start when she came out so I got and jump and it fired right up. I went to Auto Zone and they tested the battery at 100% good and the alternator pushing 14.87 volts, and the charging system checked good as well.
There have been a few times when the wife was out with the kids and it wouldn't start for her. I can't have my wife and kids in a vehicle that might not start when you turn it off. Not to mention this is my tow rid for my boat.
Any ideas?
TIA,
Jason
Battery cables and or bad grounds. I'd still change the battery. We had a battery acting similarly last month and it was making me look everywhere else but at it even though it was the troublemaker!
Welcome to the forum!
HiHoeSilver
Away!
Chicago
Any ideas?
TIA,
Jason
Remove the battery cables, clean the connections. Reinstall with a little dielectric grease good and tight.
Silent D
Silent D
You think its something as simple as a bad connection? I pulled the terminal off the first time I did a battery tender charge and the terminals and posts were nice and clean, no corrosion.
HiHoeSilver
Away!
Chicago
It's an easy thing to do and either solve the problem or rule it out, so it'd be first on my list. Sometimes the cables will corrode or even break inside the insulation, too. You can ohm out the cables while wiggling them around and see if you get varied readings.
Silent D
Silent D
Here are pics of each terminal. Nice and clean.
64C8CB08-788B-4888-87BF-7019CD5F6196.jpeg 9A74EA60-7A21-489B-BC8F-AF1E43514E2D.jpeg
HiHoeSilver
Away!
Chicago
View attachment 196100 View attachment 196101
If the truck acts dead ( assuming the battery is good under load) but perks right up when you put jumper cables on it, then the power is not getting from the battery to the wire. Take the 15 minutes to put a light sand or wire brush on those battery posts and the inside of the clamps and see what it does.
Larryjb
When this happened to me, I went over every connection and still had trouble. It turned out to be a bad starter motor. Could be a bad spot on the commutator of the starter.
HiHoeSilver
Away!
Chicago
Could be. Next time it won't start, smack on the starter with a hammer while someone tries cranking it.
Silent D
Silent D
So just cleaned the terminals. There wasn't any corrosion but the terminals and posts did have like a tarnish covering them.
I used some sandpaper and got the terminals and posts nice and shiny. I'll see if that makes a difference over the next few days.
I put the battery tender back on it too, to ensure a nice full battery.
ghostknight
