Bombsquad85
Northern VA
Yeah.. it'll be about $1k figuring they have to drop the front differential to get to the pan. Then they have to remove the transmission for the rear main seal. I don't like leaks, but the truck is giving me plenty!
You don't have to drop it, Just remove the front bolt I think and use a prybar to lift it a little its not bad i did it on my back in my driveway
Edit.... that's for the oil pan gasket I never tried the rear main seal
Chubbs
View attachment 192613 New drive belt won't fit. Tad bit smaller than the original but everything says this is supposed to work.
Follow up to this. I had another go at the new belt today & got it installed. The belt barely fits with the tensioner arm completely collapsed, or whatever you want to call it. Didn't even look right and there wasn't much pressure on the belt so I manually torqued back on it as much as possible and ran the engine for a while. I'm assuming the belt will wear down quickly enough to get the drive synced in again and I won't have to worry about it. In the meantime I will I hope for the best and inspect it after a few drive cycles if I make it that long. At least I didn't need to loosen the alternator bracket like what's his face
Prorider17
I broke both tabs on the driver side door & window switch panel...
the plastic piece next to the armrest is broken and I broke the place on the window switch panel. Is there a way to fix without buying a new door panel? New switch panel is $30, but doors are pricier! HELP PLEASE!
M1Gunner
Gainesville, Fl
I'm picking this bad boy up today. I've been looking for one for a while and almost got one of the Move DIY bumpers, but this one was such a good deal I couldn't pass it up. I'll install it Saturday and post some pics.
Fuhhh yeah!!! You can prolly smell my jealousy from here in florida lol
M1Gunner
Gainesville, Fl
So, in my down time between the carpet, new leather and inside color scheme, I’ve designed and built a custom enclosure to house 4 12’s... I was nervous as hell with the design wether it was gonna produce quality sound or not but I’m absolutely shocked with how amazing this sounds inside of the huge open cab... ridiculousness!
A1570DFC-6D1E-474C-8C21-216D005DF604.jpeg 9165AB54-CED0-4D01-886C-425D77F1D945.jpeg 973351D8-55C2-4601-A118-B819B818D656.jpeg F345E11F-1AEC-4408-BB09-965C34CADBD2.jpeg
BigDaddy13440
Rome, NY
View attachment 193536 View attachment 193537 View attachment 193538 View attachment 193539
Interesting enclosure design, never seen one like that before. I'd assume you did it that way to protect the speakers from things rolling around in the back?
What amp(s) are you pushing them with? What subs/ ohm load/ power are you pushing?
05alive
Masshole
That's quite a system
And I'm over here scratching my head about how to build a single 12 or 2/10 enclosure and how to set everything up lmao
