PPV 2" Drop From NorcalSS
992dr
N.C.
If you have 2" drop coils and no spacers on your struts, you have a 4" drop up front.
Lookin good
guy from norcal
You should have used the 10mm ring. That will give you a 2'' drop from your struts. If you didn't use any rings,That might be closer to a 2 3/4" drop with the struts.
What is your fender to ground measurements.
992dr
N.C.
Thanks @guy from norcal
@992dr - stock ppv coils, just belltech struts and didn't utilize any spacers. Pre/post measurements = -2". Is this still considered a 4" drop?
Since you had the coils in it previously, you are only measuring the 2" drop from the struts.
Yes, In total between the struts and the PPV coils, your total drop is 4" or there about :)
B
blownspyder
Stock fender to ground:
Front = 34"
Rear = 35.5"
After mods:
Front = 32"
Rear = 33.5"
Im using the 25003-008 struts, so my kit came with (8) 8mm spacers.
Per Belltech Spacer Table ....
"Lowering Height 2" - Number of Rings To Put On Strut = 0"
(meaning no rings)
SidewaystheSeven
Very nice! I've been looking for pics of lowered PPVs to see how mine might look. I like it!
griffey_mojo
