TM98
Haven’t posted in awhile but done a few things to the Escalade recently.
Replaced the wiper cowl, LH end cap & wiper arms
Installed Rockford Fosgate speakers in each door
Got the RH side door panels back on and added the gray trim along the top of the doors off an 03 EXT (it’s usually black) installed the missing woodgrain on the rear door still need to do the LH side
After replacing the drivers door I realized the front edge of the rear door was dented so picked up a door from the junkyard and threw it on I’ll see how they both look after a good buff & wax might get them painted, all that’s really left body wise now is a new front bumper, either a new or used driver side running board (it’s dented) and to cut out the rust that’s starting on the rockers on either side it’s just surface rust currently but want to stop it before it gets worse
Which wiper arms did you go with? My passenger one is not spraying correctly.
MINIz guy
I did the EGR delete on mine and the same thing happened. I ended up discharging my ac and removing the line since I had a leaking Schrader valve on the high side that I needed to replace anyway. I drilled and re-tapped the old stud. Probably no help unless you want to recharge your ac.
Yea that's what I'm trying to avoid. I have faith since there should be plenty of room with a smaller drill. I just hope my drill bits aren't too dull and I can make quick work of it.
cervantesjesus174
