2007-2014 GMC Yukon & Denali - Full LED Fog Light Kits
BFC Automotive
CO & NY
We've been offering these to our customers with builds for a little while now, making sure everything worked as planned -- they certainly do! Full product description below. Forum members can knock 10% off with code LEADINGEDGELIGHTING at checkout :)
Product Description
DESCRIPTION
No Comparison: Stock stinks! But the XB LED projector fog lights look great, are well-built and perform like champs. These have a virtually infinite life span, an unbeatable warranty and best of all you won’t need to sell your arm to afford them!
Designed: To fit the 2007-2014 GMC Yukon/Denali models as drop in replacements.
Powered: by three Nichia 5500K LED’s that produce around 1200 raw lumens per side. The projector based optics inside concentrate a total of 2400 lumens of pure white light into a beam that’s super wide and perfectly distributed for use as a fog light. They are SAE, DOT, and ECE approved.
Well-Built: Their durable polycarbonate lens should resist the test of time, keeping the housings looking new. The powder-coated cast aluminum housing is light-weight and much stronger than comparable plastic alternatives. Doubling as the heat-sink for the LED’s, the housings completely protect the internals from moisture and road debris.
Plug n Play: Wiring is easy too! The XB LED Fogs are designed to work without any special wiring. They will plug into the factory power outlets for the stock fog lights and each fog light includes all necessary connectors (as applicable), rubber seals, and pigtails for a plug n play install. NO error codes or bulb-out-warnings.
FITMENT NOTE :
Fits 2007-2014 GMC Yukon & Yukon Denali
05Single
afraid of the dark
Nice. How about 07+ tahoe / Silverado
Off Road Pedia
