MadDogDelpho
Texcellent
I had too small of a wire going to my driver front speaker, so it kept going out. I fixed that, and replaced my still-stock rear speakers with some aftermarket ones I had laying around. Sounds SO much better. Still need to figure out my sub though.
05Single
afraid of the dark
Went to put in some new LEDs inside and in the puddle lights. And was surprised that my driver was festoon as is should and my passenger was completely different. Replaced it with a 6 led 194
View attachment 182676 View attachment 182678
Wth weird. Well whatever works I guess lol. Should put cob 194s in there
. Be stupid bright.
What do you do for paint correction?
Wet sand and heavy duty compound. Clay bar is just debris removal
W8TVI
Traverse City, MI
Got the new HID kit from @Vanquish Auto installed a couple of nights ago.
They are noticeably brighter than the cheap HID kit I used before.
The new ballast also feels much heavier than the old. Reassuringly so.
Old HIDs:
Side by side (new on left):
New HIDs:
And here is a slightly darker version of the last photo where you can see the pattern just a little better:
Put on the chrome Denali handles from @fresh350. They look at with my silver speaker grilles.
Love the Denali handles. I just noticed your door panels aren't carpeted in the bottom area like mine. I had redone them with matching material when I replaced my carpet and just reglued them yesterday because I didn't use enough spray glue first time around.
I've never seen lower panels uncarpeted.
CamReynolds
I installed my differential girdle. Or should I say I had my neighbor finish installing it after nearly destroying my fractured shoulder attempting it yesterday. Actually I just dislocated it but it felt like I nearly destroyed it. RTV needs trimming but that will have to wait. BTW, if anyone wants to install a girdle but are having issues with clearance due to the panhard bar, the QA1 panhard curves out far enough to install pretty much any of the girdles out there.
why get a girdle when you have that hefty diff cover on?
Ep33401
