Front End Noise
mcorbitt52
I got both of mine swapped out yesterday right after work. MUCH better now. No noise! Except from my tires making a little more noise now because I cross rotated them. Problem solved!
Thanks to both of you for your responses. I had a very difficult time removing a stuck rotor. Ended up having to apply some heat along with a gear puller. One more question (actually two):
(1) When pulling the hub off the drive axle splines I am concerned I could have separated the inner CV joint components as I was not watching this closely as I pounded off the hub. Is there a way to test if the inner CV joint components are stilled intact without putting fully assembling the new hub and doing a test drive? I do not have a lift so I am only able to support the front of the Tahoe while working on this.
(2) how do you create a "new post". I'm a newbee and have sent a note to the administrators but have never gotten a response. Is there some sort of tutorial to follow that explains the workings of this forum?
Again, your responses have been much appreciated.
David Smith
David Smith
Savannah, GA
I do not think that it is very easy for those things to come apart, but I suppose it is possible. Can you tell if the CV boot has moved? If you pulled apart the CV joints, you would be able to see a new section of the actual shaft that was originally covered by the boot. I really think you are fine though.
David Smith
David Smith
Savannah, GA
In regards to a new posting, just click on "Forums" at the top left, and scroll on down until you see your year range and then pick a category. Click to correct category and you will see where you can create a new post.
mcorbitt52
David, many thanks for both of your replies. You've been a great help.
cmccleese
