Water leak on top console 2015 Tahoe
T
Tahoe15MA
Mine is at the dealership being replaced right now. I haven't had it a year, but when I've parked it on an incline during a heavy rain it's leaked. The first time it was facing downhill and water dripped out where the visor bolts in. Last weekend it was parked facing uphill and the rear seat belts were so wet it left a wet mark on the wife's shirt...
They are replacing it under warranty after dropping the headliner and following the water trail!
How did you make out with this?
Willard714
They covered it under warranty by claiming it was defective and could not get a signal. There is a service bulletin that covers it. I didn't debate it with them since they covered it!
T
Tahoe15MA
Here's what I hope is the final update on this. The dealership brought in an independent company that deals with testing water on vehicles. They found the leak to be coming from the firewall near the floorboard on the passenger side. So in combination of fixing that, replacing the shark fin and the seal on the sunroof, it seems that they have corrected the issue where I was getting water in two different spots.
wu6fiend
Interesting, Tahoe15MA. I'm curious about the leak from the firewall area. Was it a crack, or bad weld, or bad grommet? On our first Yukon (2005) I had a water leak, traced to a bad grommet in the drivers door. I've had the leak in our 2016 Yukon repaired (it was coming from the shark fin antenna) but would like to know more about this second source you mention.
elfro
