Air Ride Suspension
rwpaine
I own a 2007 Tahoe LTZ with air ride. I have a leak in the system. The compressor runs even when the engine isn't turned over.
Anyone have experience with this?
Thinking about taking out the air ride and putting in a regular suspension. I never pull a trailer so I don't see a problem with this. Any reason I shouldn't?
kbuskill
NE. FL.
When you say when the engine isn't turned over, I assume you mean key on engine not running, if so that is normal for it to turn on when the key is in the on position.
If it is running constantly or excessively then you have a leak in the system, as it seems you already are aware.
Normally when you turn the key on it will run for a few seconds to level itself out and then shut off.
You can get passive air shocks that will have a resistor to plug into the Autoride wiring to trick the computer into thinking that the correct shocks are there but maintain the auto leveling feature OR you can just install regular shocks and get the resistors to plug in and then pull fuse 58 in the under hood fuse block to disable the compressor.
The leak is usually in the air shock bladders but could be in the hoses as well.
fatboygixxer
Do you recommend any particular conversion kit? I'm thinking of replacing my air ride as well as I have a hole in the bag on my driver side.
kbuskill
NE. FL.
I just replaced my air shocks with the remanufactured units from Arnott.
